Aller au contenu principal
Lenovo 100e Chromebook 2nd Gen Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Keyboard: étape 1, image 1 de 1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 2, image 1 de 2 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 2, image 2 de 2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 3, image 1 de 2 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 3, image 2 de 2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Battery: étape 4, image 1 de 1
    • Remove the four 4 mm Phillips #0 screws holding the battery in.
  5. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 5, image 1 de 1
    • Using an opening pick, push on the connection where the wires are connected to the motherboard.
    • Potential for device damage: This step takes some force to disconnect, but be careful to not pull the wires out of the battery.
  6. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 6, image 1 de 1
    • The battery is now loose and can be removed from the laptop.
  7. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Screen Bezel: étape 7, image 1 de 1
    • Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
  8. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 8, image 1 de 1
    • Insert the spudger into the gap between the hinges and pull up to detach the connections.
  9. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 9, image 1 de 1
    • Remove the screen bezel from the laptop.
  10. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Display: étape 10, image 1 de 1
    • Remove the four 3.4 mm screws holding the screen in place using the Phillips #00 screwdriver.
  11. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 11, image 1 de 1
    • Carefully pull the screen back onto the lower assembly.
  12. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 12, image 1 de 3 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 12, image 2 de 3 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 12, image 3 de 3
    • Peel back the protective tape over the display cable using the spudger.
    • Gently lift the black bar latch holding the cable in place, until the cable becomes loose.
    • Pull the cable free and remove the display.
    • DO NOT pull on the cable before lifting the bar latch or the cable will break.
  13. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Hinges: étape 13, image 1 de 3 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Hinges: étape 13, image 2 de 3 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Hinges: étape 13, image 3 de 3
    • Use the Phillips #0 screwdriver to remove the six 4.7 mm screws located on the bottom half of each hinge.
    • Use the Phillips #00 screwdriver to remove the ten 3.4 mm screws located on the upper hinge assembly.
  14. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 14, image 1 de 1
    • Move the screen assembly perpendicular to the keyboard assembly.
    • Remove the hinges by pulling straight up.
  15. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Motherboard: étape 15, image 1 de 2 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Motherboard: étape 15, image 2 de 2
    • Use the spudger to disconnect the two ribbon cables.
    • Disconnect the black and white coaxial cables.
  16. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 16, image 1 de 2 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 16, image 2 de 2
    • Remove the white Lenovo sticker over one of the screws.
    • This screw conducts electricity. Remember to replace this sticker upon reassembly to avoid shorts.
    • Use the Phillips #0 screwdriver to remove the seven 3.8 mm screws.
  17. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: étape 17, image 1 de 1
    • Slide the motherboard up and out of the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 59
Total : 1,477
