Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo 300e Chromebook Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: étape 1, image 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: étape 1, image 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: étape 1, image 3 de 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook Motherboard  Replacement: étape 2, image 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement: étape 2, image 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement: étape 2, image 3 de 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook Motherboard  Replacement, Battery: étape 3, image 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement, Battery: étape 3, image 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement, Battery: étape 3, image 3 de 3
    • Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook Motherboard  Replacement: étape 4, image 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement: étape 4, image 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement: étape 4, image 3 de 3
    • Disconnect the wiring harness that connects the battery to the motherboard.
    • Lift the battery up and out of the laptop.
  5. Lenovo 300e Chromebook Motherboard  Replacement, Motherboard: étape 5, image 1 de 2 Lenovo 300e Chromebook Motherboard  Replacement, Motherboard: étape 5, image 2 de 2
    • Remove the three silver 3 mm screws from the center of the metal cover using a Phillips #00 screwdriver.
  6. Lenovo 300e Chromebook Motherboard  Replacement: étape 6, image 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement: étape 6, image 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement: étape 6, image 3 de 3
    • Remove two 3 mm screws from the top of the metal cover using a Phillips #2 screwdriver.
    • Remove the metal cover from the laptop.
  7. Lenovo 300e Chromebook Motherboard  Replacement: étape 7, image 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement: étape 7, image 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement: étape 7, image 3 de 3
    • Remove the nine 3 mm screws from the motherboard using a Phillips #2 screwdriver.
    • Detach all the connectors from the motherboard.
  8. Lenovo 300e Chromebook Motherboard  Replacement: étape 8, image 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement: étape 8, image 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement: étape 8, image 3 de 3
    • Remove the tape using a spudger.
    • Disconnect the large cable connector.
    • Remove the motherboard from the laptop.
Merit Kuykendall
Membre depuis le 09/17/21
547 Réputation
5 tutoriels rédigés
Équipe
1 commentaire de tutoriel
where is the write protect screw located im trying to install windows on this model
Harvey Willis - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 37
Total : 2,176
