Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo 300e Chromebook USB and Charging Ports Replacement
Ce dont vous avez besoin
  1. Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: étape 1, image 1 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: étape 1, image 2 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: étape 1, image 3 de 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
    Demander à FixBot
    Ajouter un commentaire
  2. Lenovo 300e Chromebook USB and Charging Ports Replacement: étape 2, image 1 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: étape 2, image 2 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: étape 2, image 3 de 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
    Demander à FixBot
  3. Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: étape 3, image 1 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: étape 3, image 2 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: étape 3, image 3 de 3
    • Remove three 5 mm screws from the USB board using a Phillips #2 screwdriver.
    Demander à FixBot
  4. Lenovo 300e Chromebook USB and Charging Ports Replacement: étape 4, image 1 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: étape 4, image 2 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: étape 4, image 3 de 3
    • Detach the white and blue ribbon cable from its cable connector on the USB board.
    • Remove the USB board from the laptop.
    Demander à FixBot
Merit Kuykendall
Membre depuis le 09/17/21
547 Réputation
5 tutoriels rédigés
Équipe
1 commentaire de tutoriel
Do you have same instructions for Lenovo 300e Gen2, I opened and usb ports are soldered with the motherboard, I am having some troubles to replace the usb c, any recommendation?
Juan Raul Hernandez - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 49
Total : 2,386
