Aller au contenu principal
Lenovo Edge 15 Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Edge 15 Battery Replacement, Battery: étape 1, image 1 de 2 Lenovo Edge 15 Battery Replacement, Battery: étape 1, image 2 de 2
    • Locate the eleven M2 x 6.0mm back-cover screws.
    • Unscrew the screws using the Phillips #0 screwdriver.
    • If battery is leaking, do not touch with bare hands.
  2. Lenovo Edge 15 Battery Replacement: étape 2, image 1 de 2 Lenovo Edge 15 Battery Replacement: étape 2, image 2 de 2
    • Gently lift the cover plate off the body of the laptop, ensuring that it does not pull on any components such as the USB ports.
  3. Lenovo Edge 15 Battery Replacement: étape 3, image 1 de 3 Lenovo Edge 15 Battery Replacement: étape 3, image 2 de 3 Lenovo Edge 15 Battery Replacement: étape 3, image 3 de 3
    • Locate the battery-connector and the three, M2 x 4.0mm screws holding the battery in place.
    • Carefully unplug the battery-connector, wiggling the connector side to side if needed.
    • Unscrew the 3-screws using the Phillips # 0 screwdriver.
  4. Lenovo Edge 15 Battery Replacement: étape 4, image 1 de 2 Lenovo Edge 15 Battery Replacement: étape 4, image 2 de 2
    • Gently lift all four corners of the battery to remove it from the laptop.
5 autres ont terminé cette réparation.
Cody Griffith
Membre depuis le 09/27/17
321 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S8-G1, Banghart Fall 2017 Membre de l'équipe Cal Poly, Team S8-G1, Banghart Fall 2017
CPSU-BANGHART-F17S8G1
5 membres
7 tutoriels rédigés
2 commentaires
Can I recharge a fully drained battery by reseating it?
Linda - Réponse
My laptop caught on fire don't recommend
Rahem Gang - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 18
30 derniers jours : 62
Total : 8,578
