Aller au contenu principal
Lenovo Edge 15 LCD Screen Replacement
Ce dont vous avez besoin
  1. Lenovo Edge 15 LCD Screen Replacement, LCD Screen: étape 1, image 1 de 1
    • Remove the black plastic or rubber screw caps covering screws, located at the bottom of the screen
  2. Lenovo Edge 15 LCD Screen Replacement: étape 2, image 1 de 2 Lenovo Edge 15 LCD Screen Replacement: étape 2, image 2 de 2
    • Remove the (2) M2.5 × 2.5 mm, Black Phillips Nylok coated screws with the Phillips #1 screwdriver, located on either side of the bottom of the screen.
  3. Lenovo Edge 15 LCD Screen Replacement: étape 3, image 1 de 1
    • Pry apart plastic cover at the bottom of the screen from plastic hinge cover.
  4. Lenovo Edge 15 LCD Screen Replacement: étape 4, image 1 de 1
    • Remove the (1) M2.5 x 2.5mm Black Phillips, Nylok coated screw located near the bottom center of the screen with the Phillips #1 screwdriver.
  5. Lenovo Edge 15 LCD Screen Replacement: étape 5, image 1 de 2 Lenovo Edge 15 LCD Screen Replacement: étape 5, image 2 de 2
    • Slide LCD screen around the edges while pulling upwards so that it pops off.
    • Turn the screen over so the touch board is visible, and start working from the back of the screen.
    • Ribbons will be connected in the back of the screen, so be careful not to pull too far that they rip out.
  6. Lenovo Edge 15 LCD Screen Replacement: étape 6, image 1 de 2 Lenovo Edge 15 LCD Screen Replacement: étape 6, image 2 de 2
    • Unplug the sensor from the sensor board near the bottom left of behind the screen.
  7. Lenovo Edge 15 LCD Screen Replacement: étape 7, image 1 de 2 Lenovo Edge 15 LCD Screen Replacement: étape 7, image 2 de 2
    • Disconnect the two ribbons from connectors from the same board from the previous step, near the bottom left of the behind the screen.
    • The ribbon connectors unlatch by pulling up on the very small brown plastic bar near the end of the ribbon.
    • Be careful not to pull on the ribbons before unlatching. This may damage the connector and/or ribbons.
  8. Lenovo Edge 15 LCD Screen Replacement: étape 8, image 1 de 2 Lenovo Edge 15 LCD Screen Replacement: étape 8, image 2 de 2
    • Remove the tape covering a ribbon connector near the bottom of the screen.
    • Disconnect the ribbon by pulling back the small grey latch on the connector and gently pulling the ribbon away.
  9. Lenovo Edge 15 LCD Screen Replacement: étape 9, image 1 de 3 Lenovo Edge 15 LCD Screen Replacement: étape 9, image 2 de 3 Lenovo Edge 15 LCD Screen Replacement: étape 9, image 3 de 3
    • Remove LCD screen by gently pulling screen away from the rest of the laptop.
    • Make sure all connections are secure when installing new screen. This eliminates the connection issue if screen is still not working properly after installation.
7 autres ont terminé cette réparation.
Gracie Harder
Membre depuis le 09/27/17
311 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S8-G1, Banghart Fall 2017 Membre de l'équipe Cal Poly, Team S8-G1, Banghart Fall 2017
CPSU-BANGHART-F17S8G1
5 membres
7 tutoriels rédigés
5 commentaires de tutoriel
Does the lcd separate from the digitizer screen or do both need to be replaced if the digitizer is cracked?
Sylvia Gagne - Réponse
Typically one can separate the LCD from the glass, but it is a difficult and painful process, and it almost always cracks the LCD. If the cost is not prohibitively expensive, I would just replace them together as one unit.
Allan Wilson -
I need that exact bottom frame strip piece replaced that they are showing in the first picture. Does anyone know where I can order one?
Josselyn Santiago - Réponse
looking to replace the whole screen, if possible even the hinge.
nasty bent screen I have for over 2+ years and I want to change that. Any advice welcomed.
frame is bent, Glass is broken in corner, touch screen gone.
Wouldnt care to install digitizer back but if I can see how to install screen components that be good.
Carry on.
Simarpreet Singh - Réponse
que tal joven talvez usted consiguió la pantalla y en que precio por que también tengo el mismo problema quiero cambiar toda la pantalla.
ToplayVid :v -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 71
Total : 11,329
