Introduction
The guide will show you how to remove the motherboard from the laptop. The process requires a lot of disarming, and a place to safely deposit screws is recommended.
Ce dont vous avez besoin
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
Using the Phillips #0 screwdriver, remove the (2) two 5.4 mm Phillips screws.
Disconnect these connectors from the motherboard.
Disconnect the four ribbon cables from the motherboard.
Unscrew and remove the (2) two Phillips #0 screws.
4 autres ont terminé cette réparation.
