Aller au contenu principal
Lenovo Essential G560 Keyboard Replacement
Ce dont vous avez besoin
  1. Lenovo Essential G560 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 Keyboard Replacement: étape 2, image 1 de 2 Lenovo Essential G560 Keyboard Replacement: étape 2, image 2 de 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 Keyboard Replacement: étape 3, image 1 de 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 Keyboard Replacement, Back Panel: étape 4, image 1 de 1
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
  5. Lenovo Essential G560 Keyboard Replacement: étape 5, image 1 de 2 Lenovo Essential G560 Keyboard Replacement: étape 5, image 2 de 2
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  6. Lenovo Essential G560 Keyboard Replacement: étape 6, image 1 de 1
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
  7. Lenovo Essential G560 Keyboard Replacement, Keyboard: étape 7, image 1 de 1
    • Remove the two 5.3 mm Phillips #1 screws from the underside of the laptop computer.
    • Remove the 4.4 mm Phillips #1 screw located next to the Fan Assembly.
  8. Lenovo Essential G560 Keyboard Replacement: étape 8, image 1 de 1
    • Flip the computer over.
    • Using the plastic opening tool, push in the four small, plastic tabs located at the top of the keyboard.
  9. Lenovo Essential G560 Keyboard Replacement: étape 9, image 1 de 1
    • Remove the keyboard by gently pulling the top loose, and then lifting the keyboard out.
    • While this step can be accomplished using your hand, it may be easier to use a spudger or plastic opening tool.
  10. Lenovo Essential G560 Keyboard Replacement: étape 10, image 1 de 1
    • Lift the keyboard up from the bezel.
    • Push the gray latch on the keyboard cable ZIF connector forward to unlock it.
    • Carefully pull the keyboard cable from its socket.
    • Be very careful while unlatching the lock on the keyboard cable ZIF connector. It is extremely delicate and can easily break.
13 autres ont terminé cette réparation.
Dennis Wong
Membre depuis le 01/11/13
609 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 18-40, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 membres
7 tutoriels rédigés
2 commentaires
Thank you frndzz
Anand krishnan - Réponse
Thank you frndz
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 38
Total : 18,600
