Aller au contenu principal
Lenovo Flex 6-11IGM Heat Sink Replacement
Ce dont vous avez besoin
  1. Lenovo Flex 6-11IGM Heat Sink Replacement, Back Panel: étape 1, image 1 de 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Heat Sink Replacement: étape 2, image 1 de 2 Lenovo Flex 6-11IGM Heat Sink Replacement: étape 2, image 2 de 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Heat Sink Replacement: étape 3, image 1 de 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Heat Sink Replacement: étape 4, image 1 de 2 Lenovo Flex 6-11IGM Heat Sink Replacement: étape 4, image 2 de 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: étape 5, image 1 de 2 Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: étape 5, image 2 de 2
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Heat Sink Replacement: étape 6, image 1 de 3 Lenovo Flex 6-11IGM Heat Sink Replacement: étape 6, image 2 de 3 Lenovo Flex 6-11IGM Heat Sink Replacement: étape 6, image 3 de 3
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Heat Sink Replacement: étape 7, image 1 de 1
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: étape 8, image 1 de 3 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: étape 8, image 2 de 3 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: étape 8, image 3 de 3
    • Disconnect the ribbon connector from both ends by disengaging the black latch and pulling it directly from its port.
  9. Lenovo Flex 6-11IGM Heat Sink Replacement: étape 9, image 1 de 2 Lenovo Flex 6-11IGM Heat Sink Replacement: étape 9, image 2 de 2
    • Remove the 3.5 mm length screws in the numbered order from 1-10 using the Phillips #00 screwdriver (not all are shown in the first image).
    • Remove the heat sink.
Rie Kuraoka
Membre depuis le 01/23/20
886 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S7-G10, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 7
Total : 288
