Introduction
If your Lenovo Flex 6-11IGM (model #: 81A70005US) can not boot or crashes regularly and you have eliminated all other possible causes, you can attempt to fix the problem by following this guide on replacing the motherboard.
The motherboard contains all the computing components of your device and their power distribution infrastructure. Damage to this part of the computer is usually non-reparable for even moderately skilled users, so the main way to fix problems caused by this component is through replacement.
Before beginning make sure you power off the device and make sure the laptop is closed for an easier and safer replacement.
Ce dont vous avez besoin
For the right speaker, disconnect the wire using the iFixit opening tool.
Pull the speaker out.
Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
Disconnect the ribbon connector from both ends by disengaging the black latch and pulling it directly from its port.
Disconnect the ribbon connector using the iFixit opening tool tool by flipping up the black flap and pulling the ribbon out.
Unscrew the single 3.5 mm screw from the RAM card using a Phillips #00 screwdriver.
Unplug from motherboard.
