Aller au contenu principal
Lenovo Flex 6-11IGM Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo Flex 6-11IGM Motherboard Replacement, Back Panel: étape 1, image 1 de 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Motherboard Replacement: étape 2, image 1 de 2 Lenovo Flex 6-11IGM Motherboard Replacement: étape 2, image 2 de 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Motherboard Replacement: étape 3, image 1 de 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Motherboard Replacement: étape 4, image 1 de 2 Lenovo Flex 6-11IGM Motherboard Replacement: étape 4, image 2 de 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Attention : les étapes 5 à 7 sont issues d'un tutoriel marqué comme en cours.
    Lenovo Flex 6-11IGM Motherboard Replacement, RAM: étape 5, image 1 de 2 Lenovo Flex 6-11IGM Motherboard Replacement, RAM: étape 5, image 2 de 2
    • Insert a plastic opening pick in the ribbon cable housing, flip the black part up, and pull the cable out with your fingers.
  6. Lenovo Flex 6-11IGM Motherboard Replacement: étape 6, image 1 de 1
    • Remove the four 3.5mm Phillips #0 screws that secure the heat sink.
    • Remove the four 3.5 mm Phillips #0 screws that secure the heat sink.
  7. Lenovo Flex 6-11IGM Motherboard Replacement: étape 7, image 1 de 1
    • Ram chips are soldered onto motherboard and cannot be removed.
  8. Lenovo Flex 6-11IGM Motherboard Replacement, Motherboard: étape 8, image 1 de 1
    • Disengage the cable located above the left speaker.
    • Disengage the ribbon cable located directly above the battery using the blue pick.
    • Disengage the battery cable directly above the ribbon cable housing.
    • Disengage the CMOS battery cable located to the right of the battery cable.
    • Remove the display cable located directly above the button battery.
    • Disengage the secondary display cable located directly to the left of the display cable.
  9. Lenovo Flex 6-11IGM Motherboard Replacement: étape 9, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the five 3.5 mm screws that secure the motherboard.
    • Using a Phillips #0 screwdriver, remove the one 3.5 mm screw that secures the Wi-Fi chip, located above the button battery.
  10. Lenovo Flex 6-11IGM Motherboard Replacement: étape 10, image 1 de 1
    • Remove the Wi-Fi chip located above the button battery from the motherboard.
    • Remove the motherboard from the case.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 17
Total : 1,030
