Aller au contenu principal
Lenovo Flex 6-11IGM Trackpad Replacement
Ce dont vous avez besoin
  1. Lenovo Flex 6-11IGM Trackpad Replacement, Back Panel: étape 1, image 1 de 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Trackpad Replacement: étape 2, image 1 de 2 Lenovo Flex 6-11IGM Trackpad Replacement: étape 2, image 2 de 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Trackpad Replacement: étape 3, image 1 de 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Trackpad Replacement: étape 4, image 1 de 2 Lenovo Flex 6-11IGM Trackpad Replacement: étape 4, image 2 de 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Trackpad Replacement, Battery: étape 5, image 1 de 2 Lenovo Flex 6-11IGM Trackpad Replacement, Battery: étape 5, image 2 de 2
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Trackpad Replacement: étape 6, image 1 de 3 Lenovo Flex 6-11IGM Trackpad Replacement: étape 6, image 2 de 3 Lenovo Flex 6-11IGM Trackpad Replacement: étape 6, image 3 de 3
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Trackpad Replacement: étape 7, image 1 de 1
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Trackpad Replacement, Trackpad: étape 8, image 1 de 2 Lenovo Flex 6-11IGM Trackpad Replacement, Trackpad: étape 8, image 2 de 2
    • Remove the connecting wire labelled "TP" by lifting the tab with the opening tool.
  9. Lenovo Flex 6-11IGM Trackpad Replacement: étape 9, image 1 de 3 Lenovo Flex 6-11IGM Trackpad Replacement: étape 9, image 2 de 3 Lenovo Flex 6-11IGM Trackpad Replacement: étape 9, image 3 de 3
    • Disconnect the keyboard ribbon from the motherboard by lifting the black tab and pulling the ribbon out with the opening tool.
  10. Lenovo Flex 6-11IGM Trackpad Replacement: étape 10, image 1 de 1
    • Pull up the black safety tape.
  11. Lenovo Flex 6-11IGM Trackpad Replacement: étape 11, image 1 de 2 Lenovo Flex 6-11IGM Trackpad Replacement: étape 11, image 2 de 2
    • Remove the three silver 2.3 mm Phillips #00 screws.
    • The third one is under the black tape.
  12. Lenovo Flex 6-11IGM Trackpad Replacement: étape 12, image 1 de 2 Lenovo Flex 6-11IGM Trackpad Replacement: étape 12, image 2 de 2
    • Slide the trackpad up from its seat using the opening tool and remove it.
Rie Kuraoka
Membre depuis le 01/23/20
886 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S7-G10, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 302
