Aller au contenu principal
Lenovo G40-30 LCD Screen Replacement
Ce dont vous avez besoin
  1. Lenovo G40-30 LCD Screen Replacement, Battery: étape 1, image 1 de 3 Lenovo G40-30 LCD Screen Replacement, Battery: étape 1, image 2 de 3 Lenovo G40-30 LCD Screen Replacement, Battery: étape 1, image 3 de 3
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 LCD Screen Replacement: étape 2, image 1 de 3 Lenovo G40-30 LCD Screen Replacement: étape 2, image 2 de 3 Lenovo G40-30 LCD Screen Replacement: étape 2, image 3 de 3
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 LCD Screen Replacement: étape 3, image 1 de 1
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 LCD Screen Replacement, LCD Screen: étape 4, image 1 de 2 Lenovo G40-30 LCD Screen Replacement, LCD Screen: étape 4, image 2 de 2
    • Use the plastic opening tool to pry the plastic away from the screen.
  5. Lenovo G40-30 LCD Screen Replacement: étape 5, image 1 de 2 Lenovo G40-30 LCD Screen Replacement: étape 5, image 2 de 2
    • Carefully unsnap the front plastic piece to expose the frame of the screen.
  6. Lenovo G40-30 LCD Screen Replacement: étape 6, image 1 de 3 Lenovo G40-30 LCD Screen Replacement: étape 6, image 2 de 3 Lenovo G40-30 LCD Screen Replacement: étape 6, image 3 de 3
    • Unscrew the four 7mm screws located on all four corners of the frame using a JIS #0 screwdriver.
    • Carefully lift the screen from the base so as to not damage it.
  7. Lenovo G40-30 LCD Screen Replacement: étape 7, image 1 de 2 Lenovo G40-30 LCD Screen Replacement: étape 7, image 2 de 2
    • Slowly remove the sticker connected to the rear of the screen using a spudger.
    • Carefully disconnect the screen from the base of the laptop.
  8. Lenovo G40-30 LCD Screen Replacement: étape 8, image 1 de 1
    • Now you have removed the screen and are ready to install a new one.
2 autres ont terminé cette réparation.
Jimmy McClenan
Membre depuis le 02/08/18
156 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team S16-G4, Nardone Spring 2018 Membre de l'équipe Sam Houston State, Team S16-G4, Nardone Spring 2018
SHSU-NARDONE-S18S16G4
5 membres
5 tutoriels rédigés
2 commentaires
Thanks alot…..I just fixed my screen by God's grace.
Nnaemeka Okechukwu - Réponse
Hi! Is it possible to replace the screen with 1080p LCD?
Chin Yau Chia - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 2,496
