Aller au contenu principal
Lenovo G50-70 Screen Replacement
Ce dont vous avez besoin
  1. Lenovo G50-70 Screen Replacement, Screen: étape 1, image 1 de 3 Lenovo G50-70 Screen Replacement, Screen: étape 1, image 2 de 3 Lenovo G50-70 Screen Replacement, Screen: étape 1, image 3 de 3
    • Push the switches outwards to release the battery.
    • It is important to remove the battery in order to avoid the laptop from turning on and avoiding any electrical issues.
  2. Lenovo G50-70 Screen Replacement: étape 2, image 1 de 3 Lenovo G50-70 Screen Replacement: étape 2, image 2 de 3 Lenovo G50-70 Screen Replacement: étape 2, image 3 de 3
    • Use a flat head screwdriver (or a plastic opening tool) to pop off the screen bezel/ plastic cover.
    • Once one side comes off you can use your hands to pull the rest of the plastic cover off; it shouldn't take much force to remove it from the device.
  3. Lenovo G50-70 Screen Replacement: étape 3, image 1 de 3 Lenovo G50-70 Screen Replacement: étape 3, image 2 de 3 Lenovo G50-70 Screen Replacement: étape 3, image 3 de 3
    • After removing the plastic cover, gently tilt and lift the screen, but do not remove it from the device.
  4. Lenovo G50-70 Screen Replacement: étape 4, image 1 de 3 Lenovo G50-70 Screen Replacement: étape 4, image 2 de 3 Lenovo G50-70 Screen Replacement: étape 4, image 3 de 3
    • Using a Phillips #00 screwdriver, remove four 3.5 mm screws at the top right and left side of the screen.
  5. Lenovo G50-70 Screen Replacement: étape 5, image 1 de 3 Lenovo G50-70 Screen Replacement: étape 5, image 2 de 3 Lenovo G50-70 Screen Replacement: étape 5, image 3 de 3
    • Using the same Phillips #00 screwdriver, remove the four 3.5 mm screws at the bottom of the screen.
  6. Lenovo G50-70 Screen Replacement: étape 6, image 1 de 3 Lenovo G50-70 Screen Replacement: étape 6, image 2 de 3 Lenovo G50-70 Screen Replacement: étape 6, image 3 de 3
    • Once the screen is loose and can be moved around, make sure to readjust the laptop gently.
    • Lay the screen flat on the keyboard in order to make it easier to find the connector.
  7. Lenovo G50-70 Screen Replacement: étape 7, image 1 de 3 Lenovo G50-70 Screen Replacement: étape 7, image 2 de 3 Lenovo G50-70 Screen Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Using a pair of tweezers, peel the sticker to off of the device.
  8. Lenovo G50-70 Screen Replacement: étape 8, image 1 de 3 Lenovo G50-70 Screen Replacement: étape 8, image 2 de 3 Lenovo G50-70 Screen Replacement: étape 8, image 3 de 3
    • Carefully disconnect the display cable from the rest of the screen.
  9. Lenovo G50-70 Screen Replacement: étape 9, image 1 de 1
    • Remove the screen from the device.
2 autres ont terminé cette réparation.
Brandon Navas
Membre depuis le 10/05/21
217 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 11-8, Grodsky Fall 2021 Membre de l'équipe CSU Los Angeles, Team 11-8, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G8
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 39
Total : 1,510
