Aller au contenu principal
Lenovo G50-80 80E5 RAM Replacement
Ce dont vous avez besoin
  1. Lenovo G50-80 80E5 RAM Replacement, Battery: étape 1, image 1 de 1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 RAM Replacement: étape 2, image 1 de 3 Lenovo G50-80 80E5 RAM Replacement: étape 2, image 2 de 3 Lenovo G50-80 80E5 RAM Replacement: étape 2, image 3 de 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 RAM Replacement: étape 3, image 1 de 3 Lenovo G50-80 80E5 RAM Replacement: étape 3, image 2 de 3 Lenovo G50-80 80E5 RAM Replacement: étape 3, image 3 de 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 RAM Replacement: étape 4, image 1 de 3 Lenovo G50-80 80E5 RAM Replacement: étape 4, image 2 de 3 Lenovo G50-80 80E5 RAM Replacement: étape 4, image 3 de 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 RAM Replacement, Bottom Access Panel: étape 5, image 1 de 2 Lenovo G50-80 80E5 RAM Replacement, Bottom Access Panel: étape 5, image 2 de 2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 RAM Replacement: étape 6, image 1 de 2 Lenovo G50-80 80E5 RAM Replacement: étape 6, image 2 de 2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 RAM Replacement, RAM: étape 7, image 1 de 2 Lenovo G50-80 80E5 RAM Replacement, RAM: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use the tweezers to push the two silver clips to the left and right of the RAM chip outwards.
    • The RAM will release after pushing the second clip.
  8. Lenovo G50-80 80E5 RAM Replacement: étape 8, image 1 de 1
    • Use your fingers to carefully remove the RAM chip by sliding it out at a ~45° angle.
Noah Baldwin
Membre depuis le 02/08/22
350 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 27
Total : 1,234
