Introduction
The laptop wil need to be completely disassembled and the motherboard pulled before removal of a USB port can begin.
Ce dont vous avez besoin
From the underside of the laptop, press the two battery tabs inward to remove the battery. Lift the battery to remove.
Flip the laptop over, lift the screen and with a plastic spudger begin to remove the keyboard. Start at the top left corner and work from left to right lifting the keyboard. Once the top section is free, lift the keyboard up and away from yourself. Remove the ribbon cable connection and set the keyboard aside.
Un commentaire
What kind of port is this? THT/SMD? THT even or scrambled( offset ) set of THT elements? Four latch pins make it look like: https://cy.rsdelivers.com/product/wurth-...
