Introduction
At some point in your lifetime, you'll probably end up in this situation: You own a perfectly good laptop, but you've broken the screen! By utilizing this guide, you can save yourself time and money while learning more about your computer! This guide will explain, step-by-step, how to replace the screen in your Lenovo G570 notebook computer.
Ce dont vous avez besoin
Order a replacement screen for your laptop! Screens for this laptop (and almost any other model) can be found at https://www.laptopscreen.com/.
Gather the necessary tools, and make sure you have a large open space (such as a workbench) to work on.
Remove the front plastic bezel from the screen using the following steps.
Pry up the bezel in the location depicted with a plastic opening tool or small flat-head screwdriver until you free the first few retaining clips.
Once a few clips are loosened, you can pry the bezel the rest of the way off by hand.
To do so, pull each side of the bezel outward and towards the center of the screen, until all of the retaining clips have been released.
15 autres ont terminé cette réparation.
Un commentaire
You should mention in step 7 how to recognise if screen is LED or CCFL.
