Aller au contenu principal
Lenovo G70-70 Keyboard Replacement
Ce dont vous avez besoin
  1. Lenovo G70-70 Keyboard Replacement, Battery: étape 1, image 1 de 2 Lenovo G70-70 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Ensure the battery is removed before attempting to fix anything on the laptop.
    • Orient the laptop so the bottom side is facing you.
    • To unlock the battery, place your thumb over the left switch and slide it to the left.
  2. Lenovo G70-70 Keyboard Replacement: étape 2, image 1 de 2 Lenovo G70-70 Keyboard Replacement: étape 2, image 2 de 2
    • To access the battery, place your thumb over the right switch and slide it to the right.
    • When the battery is unlocked, it will automatically pop up.
  3. Lenovo G70-70 Keyboard Replacement: étape 3, image 1 de 3 Lenovo G70-70 Keyboard Replacement: étape 3, image 2 de 3 Lenovo G70-70 Keyboard Replacement: étape 3, image 3 de 3
    • Remove the battery by lifting it up and away from yourself.
  4. Lenovo G70-70 Keyboard Replacement, Keyboard: étape 4, image 1 de 3 Lenovo G70-70 Keyboard Replacement, Keyboard: étape 4, image 2 de 3 Lenovo G70-70 Keyboard Replacement, Keyboard: étape 4, image 3 de 3
    • Turn your laptop so the bottom side is facing you.
    • Remove two 7.3 mm Phillips #0 screws.
    • Slide the back cover towards yourself.
  5. Lenovo G70-70 Keyboard Replacement: étape 5, image 1 de 3 Lenovo G70-70 Keyboard Replacement: étape 5, image 2 de 3 Lenovo G70-70 Keyboard Replacement: étape 5, image 3 de 3
    • Lift the back cover from the far side towards yourself to remove it.
    • Remove three 6.2 mm Phillips #0 screws.
    • The label M2X6 is written next to each screw that keeps the keyboard secure.
  6. Lenovo G70-70 Keyboard Replacement: étape 6, image 1 de 3 Lenovo G70-70 Keyboard Replacement: étape 6, image 2 de 3 Lenovo G70-70 Keyboard Replacement: étape 6, image 3 de 3
    • Turn the laptop over so the top side is facing you and open the laptop.
    • Carefully pry open any corner of the keyboard with the metal spudger.
    • Slide the metal spudger around the perimeter of the keyboard until you can lift it.
    • You will hear loud popping noises as the keyboard separates from the laptop.
  7. Lenovo G70-70 Keyboard Replacement: étape 7, image 1 de 2 Lenovo G70-70 Keyboard Replacement: étape 7, image 2 de 2
    • Carefully lift the keyboard.
    • Use your finger or the opening tool to pull the locking flap toward yourself.
  8. Lenovo G70-70 Keyboard Replacement: étape 8, image 1 de 2 Lenovo G70-70 Keyboard Replacement: étape 8, image 2 de 2
    • Pull the silver ribbon cable away from you to disconnect the keyboard.
    • Remove the keyboard from the laptop.
2 autres ont terminé cette réparation.
Joseph Crews
Membre depuis le 09/15/22
842 Réputation
5 tutoriels rédigés
Équipe
University of Memphis, Team 3-3, Lane Fall 2022 Membre de l'équipe University of Memphis, Team 3-3, Lane Fall 2022
UM-LANE-F22S3G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 164
