Introduction
This requires a Phillips head screwdriver.
Pièces
Aucune pièce nécessaire.
Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
  • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
  • Make sure that the work surface is flat and has nothing sharp on it.
Ajouter un commentaire
Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  • Remove the two screws on the bottom of the computer, one on each side.
  • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  • Once it has been separated, lift to remove.
  • Remove the four screws that secure the arm stand.
  • Lift up to remove the arm stand.
  • Remove the 5 screws that secure the EMI cover.
  • Remove the cover.
Jackson Blake
Membre depuis le 22/01/2018
805 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team S16-G3, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 47
