Aller au contenu principal
Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement, Stand Base: étape 1, image 1 de 1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement: étape 2, image 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement: étape 2, image 2 de 2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement, Back Cover: étape 3, image 1 de 1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement: étape 4, image 1 de 3 Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement: étape 4, image 2 de 3 Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement: étape 4, image 3 de 3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement: étape 5, image 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement: étape 5, image 2 de 2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement, Arm Stand: étape 6, image 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement, Arm Stand: étape 6, image 2 de 2
    • Remove the four screws that secure the arm stand.
  7. Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement: étape 7, image 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement: étape 7, image 2 de 2
    • Lift up to remove the arm stand.
  8. Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement, EMI Cover: étape 8, image 1 de 3 Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement, EMI Cover: étape 8, image 2 de 3 Lenovo IdeaCentre AIO 510S-23ISU EMI Cover Replacement, EMI Cover: étape 8, image 3 de 3
    • Remove the 5 screws that secure the EMI cover.
    • Remove the cover.
Jackson Blake
Membre depuis le 01/22/18
1 119 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team S16-G3, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 671
