Aller au contenu principal
Lenovo IdeaPad 1 14IGL7 Battery Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 1 14IGL7 Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Power off your laptop before beginning disassembly.
    • Place the computer upside down on a flat surface.
  2. Lenovo IdeaPad 1 14IGL7 Battery Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 1 14IGL7 Battery Replacement: étape 2, image 2 de 2
    • Remove the nine 7 mm screws from the back panel using a Phillips #00 screwdriver.
  3. Lenovo IdeaPad 1 14IGL7 Battery Replacement: étape 3, image 1 de 1
    • Insert an opening pick between the back panel and the body of the laptop.
    • Pry up the latches around the back panel and remove the panel from the laptop.
  4. Lenovo IdeaPad 1 14IGL7 Battery Replacement, Battery: étape 4, image 1 de 2 Lenovo IdeaPad 1 14IGL7 Battery Replacement, Battery: étape 4, image 2 de 2
    • Remove the six 5.5 mm screws that secure the battery using a Phillips #00 screwdriver.
  5. Lenovo IdeaPad 1 14IGL7 Battery Replacement: étape 5, image 1 de 2 Lenovo IdeaPad 1 14IGL7 Battery Replacement: étape 5, image 2 de 2
    • Gently pull on the cable attached to the motherboard in the same direction as the individual wires are running.
    • Be sure to ground yourself by wearing the anti-shock wristband to prevent damage to the components.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Lenovo IdeaPad 1 14IGL7 Battery Replacement: étape 6, image 1 de 1
    • Remove the battery.
3 autres ont terminé cette réparation.
Nicole Loiselle
Membre depuis le 03/18/24
253 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-6, Konn Spring 2024 Membre de l'équipe UMass Dartmouth, Team 1-6, Konn Spring 2024
UMASSD-KONN-S24S1G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 47
Total : 557
