Introduction
In cases of hard drive or SSD issues, removing the defective hardware may be necessary. This guide demonstrates how to remove the SSD from the Lenovo IdeaPad 100S-141BR.
Required items will be a Phillips #00 Screwdriver and a Spudger. The removal process is simple and requires little to no experience to complete.
It is also recommended to have a replacement drive ready to replace it, but this is not required.
Ce dont vous avez besoin
Remove the eight 4mm PH00 screws.
Remove the four 2mm PH00 screws.
6 autres ont terminé cette réparation.
3 commentaires
WHAT DO i REPLACE THE ssd WITH ONCE REMOVED? I WANT TO UPGRADE TO A 1TB DRIVE. WHAT DO YOU SUGGEST FOR MY LENOVO 110S-141BR LAPTOP?
I replaced with an ssd but the laptop is not recognizing it
merci beaucoup
