Aller au contenu principal
Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement, USB/Headphones Jack: étape 1, image 1 de 1
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: étape 2, image 2 de 2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: étape 3, image 1 de 1
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: étape 4, image 1 de 1
    • Remove the three 4mm PH00 screws.
    • Unplug the ribbon wire connected to the USB/Headphone Jack PCB by lifting the black plastic tab holding the ribbon cable down.
    • Be extra careful not to bend the ribbon cable too much as it is fragile.
  5. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: étape 5, image 1 de 2 Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: étape 5, image 2 de 2
    • Lift the USB/Headphone Jack PCB off of the board gently and put it to the side.
Mohammed Younis
Membre depuis le 03/18/19
421 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 13
Total : 842
