Aller au contenu principal
Lenovo IdeaPad 110-15IBR Display Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 110-15IBR Display Replacement, Display: étape 1, image 1 de 3 Lenovo IdeaPad 110-15IBR Display Replacement, Display: étape 1, image 2 de 3 Lenovo IdeaPad 110-15IBR Display Replacement, Display: étape 1, image 3 de 3
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source.
    • Using a plastic opening tool, gently pry the cover off of the display.
    • Lay screen flat down to remove the tabs from each corner.
  2. Lenovo IdeaPad 110-15IBR Display Replacement: étape 2, image 1 de 1
    • Using the #1 Phillips head screwdriver unscrew the 4 (9mmx6mm) screws holding the screen in place.
  3. Lenovo IdeaPad 110-15IBR Display Replacement: étape 3, image 1 de 2 Lenovo IdeaPad 110-15IBR Display Replacement: étape 3, image 2 de 2
    • Carefully lay the screen facing down on the keyboard.
    • Careful not to lift the screen to high up or tug on the screen due to a wire still being connected to the screen and display.
  4. Lenovo IdeaPad 110-15IBR Display Replacement: étape 4, image 1 de 2 Lenovo IdeaPad 110-15IBR Display Replacement: étape 4, image 2 de 2
    • Remove the tape holding the connected wire to the display.
    • Gently remove the display wire from the connection.
    • Remove the display from the device.
13 autres ont terminé cette réparation.
Saddam Alsinai
Membre depuis le 10/18/17
669 Réputation
4 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G4, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G4, Liner Fall 2017
UWT-LINER-F17S3G4
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 25
Total : 5,175
