Introduction
If the Lenovo is unable to read a disc, the optical drive may be broken. To replace the optical drive, follow the provided guide.
Ce dont vous avez besoin
Flip the IdeaPad bottom side up.
Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
Flip the computer back to top facing.
Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
Un commentaire
Hi, I have an Lenovo ideapad 110-15isk laptop. The size of the optical drive is 9.0 mm. Can I trace the 9.5 mm specimens ??because there is no 9.0 mimeter available now? Thanks s lot.
