Introduction
Verify whether the laptop makes a whirring sound when it is turned on in case it starts to overheat. If the laptop is silent, it can experience a thermal cool down, which is indicative of a malfunctioning cooling fan. You can replace the cooling fan by following the instructions in this article.
Ce dont vous avez besoin
Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
Unscrew the four 6 mm Phillips #0 screws that secure the fan.
Push the white fan connector directly out of its port tweezers or a pry tool.
Lift the fan up and out of the chassis.
