Aller au contenu principal
Lenovo IdeaPad 130-15AST Speaker Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 130-15AST Speaker Replacement, DVD/CD Optical Drive: étape 1, image 1 de 1
    • Verify that the DVD/CD Tray is free of DVD's and CD's.
    • Using a Phillips #00 screwdriver, remove one of the 6.0mm screws.
  2. Lenovo IdeaPad 130-15AST Speaker Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 130-15AST Speaker Replacement: étape 2, image 2 de 2
    • Using the Jimmy Tool, gently pry the DVD/CD Drive away from the case of the laptop.
  3. Lenovo IdeaPad 130-15AST Speaker Replacement: étape 3, image 1 de 1
    • Gently slide the DVD/CD Drive out of the laptop.
  4. Lenovo IdeaPad 130-15AST Speaker Replacement, Battery: étape 4, image 1 de 1
    • Before proceeding, make sure the computer is turned off and it is not connected to any power source.
    • Using a Phillips #00 screwdriver, remove twelve of the 6.0mm screws.
  5. Lenovo IdeaPad 130-15AST Speaker Replacement: étape 5, image 1 de 3 Lenovo IdeaPad 130-15AST Speaker Replacement: étape 5, image 2 de 3 Lenovo IdeaPad 130-15AST Speaker Replacement: étape 5, image 3 de 3
    • Do not try to completely remove this case without ensuring the entire case is free of connection points as this could crack or damage the case.
    • Use a thin, flat edge to gently break the seal of the case.
  6. Lenovo IdeaPad 130-15AST Speaker Replacement: étape 6, image 1 de 2 Lenovo IdeaPad 130-15AST Speaker Replacement: étape 6, image 2 de 2
    • Make sure that the back panel is completely free from the laptop.
    • Grab the sides of the back panel of the laptop with two hands. Then separate the panel from the laptop by lifting up.
  7. Lenovo IdeaPad 130-15AST Speaker Replacement: étape 7, image 1 de 1
    • Using a Phillips #0 screwdriver, remove three 6.0mm screws.
  8. Lenovo IdeaPad 130-15AST Speaker Replacement: étape 8, image 1 de 3 Lenovo IdeaPad 130-15AST Speaker Replacement: étape 8, image 2 de 3 Lenovo IdeaPad 130-15AST Speaker Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Using a pair of tweezers, remove the black plug which includes 8 wires.
  9. Lenovo IdeaPad 130-15AST Speaker Replacement: étape 9, image 1 de 2 Lenovo IdeaPad 130-15AST Speaker Replacement: étape 9, image 2 de 2
    • Grabbing the sides of the battery with one hand, remove the battery from the laptop.
  10. Lenovo IdeaPad 130-15AST Speaker Replacement, Speaker: étape 10, image 1 de 1
    • Using a prying tool, remove the white plug (which includes 4 different colored wires) from the motherboard. Repeat the same step for the other plug.
    • This plug is small and fragile. You should not use a lot of force to separate the plastic connection from the motherboard.
  11. Lenovo IdeaPad 130-15AST Speaker Replacement: étape 11, image 1 de 1
    • Disconnect the speaker wires from their connection tabs along the front of the computer.
    • These wires are not connected to anything internally. They connect the speakers from the power supply to each other.
  12. Lenovo IdeaPad 130-15AST Speaker Replacement: étape 12, image 1 de 2 Lenovo IdeaPad 130-15AST Speaker Replacement: étape 12, image 2 de 2
    • To remove the speakers, pinch the inside edge and lift upwards.
    • These speakers are help in by O-rings. Be sure not to lose these, as new speakers do not come with new O-rings.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 930
