Introduction
Use this guide to replace the facility fan in your Lenovo IdeaPad 3-15ADA05. Before using this guide, be sure to review the troubleshooting page to ensure the fan is the problem. If the computer was recently used, give it 5 to 10 minutes to cool down.
Ce dont vous avez besoin
Remove the six 5 mm screws located at the top half of the laptop using a Phillips #0 screwdriver.
Remove the four 2.5 mm screws located at the bottom of the laptop using a Phillips #0 screwdriver.
Remove the two M2 x 3.30mm screws using the #0 screw head, then remove the one M2 x 5mm screw using the #0 screw head.
2 autres ont terminé cette réparation.
