Introduction
Use this guide to replace the heat sink in the computer: Lenovo IdeaPad 3-15ADA05. This laptop is known for its efficiency and screen. The heat sink in a computer works to absorb and disperse the computer's heat. This instruction also includes removing the thermal paste.
Before removing the heat sink, make sure that the heat sink or thermal paste is the problem. To do this, refer to the troubleshooting page
To begin, check that you powered off the device. Then, begin the instruction and review the needed materials.
Ce dont vous avez besoin
Remove the six 5 mm screws from the back of the laptop using a Phillips #0 screwdriver.
Remove the four 2.5 mm screws from the back of the laptop using a Phillips #0 screwdriver.
