Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo IdeaPad 3-15ADA05 Motherboard Replacement
Ce dont vous avez besoin
    1. Lenovo IdeaPad 3-15ADA05 Motherboard Replacement, Back Panel: étape 1, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Motherboard Replacement, Back Panel: étape 1, image 2 de 2
      • Remove the six 5 mm screws located at the top half of the laptop using a Phillips #0 screwdriver.
      • Remove the four 2.5 mm screws located at the bottom of the laptop using a Phillips #0 screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 2, image 2 de 2
      • Insert the opening pick between the base plate and the bottom of the laptop and pry the clips loose around the edge until the base pops off.
      Demander à FixBot
    1. Lenovo IdeaPad 3-15ADA05 Motherboard Replacement, Battery: étape 3, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Motherboard Replacement, Battery: étape 3, image 2 de 2
      • Using a #0 Phillips head, remove the five M2 x 3.5mm screws holding the battery in place.
      Demander à FixBot
    2. Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 4, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 4, image 2 de 2
      • Using the opening tool, disconnect the battery connector from the motherboard, and then remove the battery.
      Demander à FixBot
    1. Lenovo IdeaPad 3-15ADA05 Motherboard Replacement, Fan: étape 5, image 1 de 3 Lenovo IdeaPad 3-15ADA05 Motherboard Replacement, Fan: étape 5, image 2 de 3 Lenovo IdeaPad 3-15ADA05 Motherboard Replacement, Fan: étape 5, image 3 de 3
      • Remove the two M2 x 3.30mm screws using the #0 screw head, then remove the one M2 x 5mm screw using the #0 screw head.
      Demander à FixBot
    2. Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 6, image 1 de 3 Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 6, image 2 de 3 Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 6, image 3 de 3
      • Disconnect the black and white antenna cables from the wireless card using the opening tool.
      Demander à FixBot
    3. Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 7, image 1 de 3 Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 7, image 2 de 3 Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 7, image 3 de 3
      • Disconnect the fan cable from the motherboard using the opening tool.
      Demander à FixBot
    4. Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 8, image 1 de 3 Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 8, image 2 de 3 Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 8, image 3 de 3
      • Unwrap the cord from the three clips, then remove the fan.
      • To remove the cords, push them through the small gap shown by the arrow.
      Demander à FixBot
    1. Lenovo IdeaPad 3-15ADA05 Motherboard Replacement, Motherboard: étape 9, image 1 de 1
      • Use a Phillips #00 screwdriver to loosen the four 2.5 mm screws from the heat sink.
      • Remove the heat sink from the motherboard.
      Demander à FixBot
    2. Lenovo IdeaPad 3-15ADA05 Motherboard Replacement: étape 10, image 1 de 1
      • Use a Phillips #00 screwdriver to remove the ten 2.5 mm screws.
      • Disconnect the cable from the motherboard using an opening tool.
      • Remove the CMOS battery that is adhered to the laptop.
      • Remove the motherboard.
      Demander à FixBot
Nicholas Scholz
Membre depuis le 02/25/25
196 Réputation
2 tutoriels rédigés
Équipe
University of Kentucky, Team 1-5, Frey Spring 2025 Membre de l'équipe University of Kentucky, Team 1-5, Frey Spring 2025
UKY-FREY-S25S1G5
5 membres
54 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 83
Total : 889
