Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo IdeaPad 3-15ADA05 Touchpad Replacement
Ce dont vous avez besoin
    1. Lenovo IdeaPad 3-15ADA05 Touchpad Replacement, Back Panel: étape 1, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Touchpad Replacement, Back Panel: étape 1, image 2 de 2
      • Remove the six 5 mm screws located at the top half of the laptop using a Phillips #0 screwdriver.
      • Remove the four 2.5 mm screws located at the bottom of the laptop using a Phillips #0 screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Lenovo IdeaPad 3-15ADA05 Touchpad Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Touchpad Replacement: étape 2, image 2 de 2
      • Insert the opening pick between the base plate and the bottom of the laptop and pry the clips loose around the edge until the base pops off.
      Demander à FixBot
    1. Lenovo IdeaPad 3-15ADA05 Touchpad Replacement, Battery: étape 3, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Touchpad Replacement, Battery: étape 3, image 2 de 2
      • Using a #0 Phillips head, remove the five M2 x 3.5mm screws holding the battery in place.
      Demander à FixBot
    2. Lenovo IdeaPad 3-15ADA05 Touchpad Replacement: étape 4, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Touchpad Replacement: étape 4, image 2 de 2
      • Using the opening tool, disconnect the battery connector from the motherboard, and then remove the battery.
      Demander à FixBot
    1. Lenovo IdeaPad 3-15ADA05 Touchpad Replacement, Touchpad: étape 5, image 1 de 1
      • Remove the five 2.5 mm screws securing the motherboard and fan to the chassis.
      Demander à FixBot
    2. Lenovo IdeaPad 3-15ADA05 Touchpad Replacement: étape 6, image 1 de 1
      • Lift the motherboard to gain access to the screws that are securing the touchpad.
      • Remove the two 2.5 mm screws securing the touchpad.
      Demander à FixBot
    3. Lenovo IdeaPad 3-15ADA05 Touchpad Replacement: étape 7, image 1 de 1
      • Pull the touchpad to the inside of the chassis.
      • Remove the touchpad from the laptop.
      Demander à FixBot
2 autres ont terminé cette réparation.
Andres UKY
Membre depuis le 02/25/25
124 Réputation
1 tutoriel rédigé
Équipe
University of Kentucky, Team 1-5, Frey Spring 2025 Membre de l'équipe University of Kentucky, Team 1-5, Frey Spring 2025
UKY-FREY-S25S1G5
5 membres
72 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 18
30 derniers jours : 82
Total : 913
