Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement
Ce dont vous avez besoin
    1. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement, Back Panel: étape 1, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement, Back Panel: étape 1, image 2 de 2
      • Remove the six 5 mm screws located at the top half of the laptop using a Phillips #0 screwdriver.
      • Remove the four 2.5 mm screws located at the bottom of the laptop using a Phillips #0 screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: étape 2, image 2 de 2
      • Insert the opening pick between the base plate and the bottom of the laptop and pry the clips loose around the edge until the base pops off.
      Demander à FixBot
    1. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement, Battery: étape 3, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement, Battery: étape 3, image 2 de 2
      • Using a #0 Phillips head, remove the five M2 x 3.5mm screws holding the battery in place.
      Demander à FixBot
    2. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: étape 4, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: étape 4, image 2 de 2
      • Using the opening tool, disconnect the battery connector from the motherboard, and then remove the battery.
      Demander à FixBot
    1. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 2 de 2
      • Grip each cable by using the angled tweezers and gently pull it straight out.
      • This will allow you to disconnect the black and white antenna cables from the Wi-Fi card.
      Demander à FixBot
    2. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: étape 6, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: étape 6, image 2 de 2
      • Remove the 3.0 mm screw using a Phillips #00 screwdriver.
      Demander à FixBot
    3. Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: étape 7, image 1 de 2 Lenovo IdeaPad 3-15ADA05 Wi-Fi Card Replacement: étape 7, image 2 de 2
      • Pull the Wi-Fi card to the left to remove it.
      Demander à FixBot
Kate Zeiher
Membre depuis le 03/04/25
97 Réputation
1 tutoriel rédigé
Équipe
University of Kentucky, Team 1-5, Frey Spring 2025 Membre de l'équipe University of Kentucky, Team 1-5, Frey Spring 2025
UKY-FREY-S25S1G5
5 membres
54 tutoriels rédigés
1 commentaire de tutoriel
Hi Kate! thanks for your instruction on how to open and change the WiFi module... I have a question about the version of M.2 Key E wich are compatible with this Laptop.
The original one is a M.2 Key A+E RTL8822CE from REALTEK. I think this is giving me a problem with WHEA_UNCORRECTABLE_ERROR Blue Screen issue. So I take it off and then not problems are visibles, everything works fine.
So I take off the WiFi module from a LENOVO L340 wich it comes with INTEL 9462NGW, M.2 Key E form factor. Is not working.
I look into the respective Schematics and foun that Lenovo ideaPad 3 doesn't have some conections lines (SPI,UART,others), just USB conections... so i think there is a problem with Key E types wich wont works withs this Laptop.
So question is... Do am I ok?? Does Key E need all pins connection? I will looking for more info, so if I coul answer me will share it too here!
I hope you all community still fine! Cheers!
NicoTiza - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 55
Total : 731
