Aller au contenu principal
Lenovo IdeaPad 3-15IGL05 SSD Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 3-15IGL05 SSD Replacement, SSD: étape 1, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the ten 7.6 mm screws securing the bottom panel.
  2. Lenovo IdeaPad 3-15IGL05 SSD Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 3-15IGL05 SSD Replacement: étape 2, image 2 de 2
    • Wedge an opening tool in the gap between the bottom panel and chassis, and pry vertically around the perimeter until you hear a "pop" and the panel releases.
    • Lift the bottom panel up and off the chassis.
  3. Lenovo IdeaPad 3-15IGL05 SSD Replacement: étape 3, image 1 de 2 Lenovo IdeaPad 3-15IGL05 SSD Replacement: étape 3, image 2 de 2
    • Locate the SSD at the bottom right corner of the fan.
    • Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the SSD.
    • The drive should slightly lift once the screw is removed.
  4. Lenovo IdeaPad 3-15IGL05 SSD Replacement: étape 4, image 1 de 1
    • Gently pull the SSD directly out of its port.
    • Do not over-tighten the screws during reassembly.
Matthew Frederic
Membre depuis le 09/30/21
109 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 14
30 derniers jours : 103
Total : 2,545
