Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Pièces
Aucune pièce spécifiée.
  1. Flip laptop over and remove 13 screws from the bottom panel. Remove RAM panel after removing 3 screws.
    • Flip laptop over and remove 13 screws from the bottom panel.
    • Remove RAM panel after removing 3 screws.
  2. Disconnect keyboard and touchpad wire. Remove CD port.
    • Disconnect keyboard and touchpad wire.
    • Remove CD port.
  3. Flip laptop back over. Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
    • Flip laptop back over.
    • Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
  4. Remove the 5 screws and 4 tabs holding the motherboard and remove. Before removing motherboard, be sure to disconnect the fan tab on the bottom. Before removing motherboard, be sure to disconnect the fan tab on the bottom.
    • Remove the 5 screws and 4 tabs holding the motherboard and remove.
    • Before removing motherboard, be sure to disconnect the fan tab on the bottom.
  5. Unscrew the 2 screws and 1 pull tab holding the battery in place. Carefully remove battery.
    • Unscrew the 2 screws and 1 pull tab holding the battery in place.
    • Carefully remove battery.
Cam Plute
Membre depuis le 26/09/2017
153 Réputation
1 tutoriel rédigé
Équipe
Washington State, Team S5-G7, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S5-G7, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G7
4 membres
6 tutoriels rédigés
Step 2 should include removing connectors for the wireless card.
Ronn Richardson - Réponse
Thanks for your commentary, I have added this in my French translation but I don’t know why I can’t modify the tutorial in English.. Maybe because I am a French member..
Zacharie Troletti-Gillot -
The fan should also be disconnected in step 2 not step 4.
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 12
7 derniers jours : 82
30 derniers jours : 409
Total : 10,396
