Aller au contenu principal
Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Lower Case: étape 1, image 1 de 1
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: étape 2, image 1 de 2 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: étape 2, image 2 de 2
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 1 de 3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 2 de 3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: étape 3, image 3 de 3
    • Remove the two Wi-Fi card's connections by gently lifting up on the connectors.
  4. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: étape 4, image 1 de 3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: étape 4, image 2 de 3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: étape 4, image 3 de 3
    • Remove the single Phillips #0 screw securing the Wi-Fi card.
  5. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: étape 5, image 1 de 2 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: étape 5, image 2 de 2
    • Slide the Wi-Fi card out of its port on the motherboard.
    • Do not worry about the angle the card sits after removing the mounting screw - this is how it's meant to be connected and will have to be connected similarly during reassembly.
Brayden Fleming
Membre depuis le 09/22/22
479 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 26
Total : 262
