Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Lenovo IdeaPad 330-15IGM Speaker Units Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Back Cover: étape 1, image 1 de 3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Back Cover: étape 1, image 2 de 3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Back Cover: étape 1, image 3 de 3
    • Press and hold the power button to power off the computer.
    Demander à FixBot
    Ajouter un commentaire
  2. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: étape 2, image 1 de 1
    • Remove thirteen 6.5 mm screws from the laptop cover using a Phillips #00 screwdriver.
    Demander à FixBot
  3. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: étape 3, image 1 de 1
    • Use your hands to remove the back cover from the laptop.
    Demander à FixBot
  4. Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Battery: étape 4, image 1 de 1
    • Remove four 5.7 mm screws that hold the battery unit in place using a Phillips #00 screwdriver.
    Demander à FixBot
  5. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: étape 5, image 1 de 3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: étape 5, image 2 de 3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: étape 5, image 3 de 3
    • Detach the cable connecting the battery to the motherboard.
    Demander à FixBot
  6. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: étape 6, image 1 de 1
    • Remove the battery from the laptop.
    Demander à FixBot
  7. Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Speaker Units: étape 7, image 1 de 2 Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Speaker Units: étape 7, image 2 de 2
    • Carefully disconnect the speaker from the motherboard.
    • Each speaker unit has blue stoppers that allow it to remain in place. In order to remove the unit, you must nudge the blue stoppers off of the plastic piece it is attached to. Repeat for each speaker.
    Demander à FixBot
  8. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: étape 8, image 1 de 3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: étape 8, image 2 de 3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: étape 8, image 3 de 3
    • Remove the unit from the chassis and carefully remove the cable that connects the two speaker units together.
    • This cable is vital since it is the only thing that connects the speaker units and allows them to share audio from the motherboard.
    Demander à FixBot
Emmanuel Guadarrama
Membre depuis le 08/24/22
478 Réputation
5 tutoriels rédigés
Équipe
Gateway, Team 1-2, Class Fall 2022 Membre de l'équipe Gateway, Team 1-2, Class Fall 2022
GCC-CLASS-F22S1G2
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 28
Total : 436
