Introduction
Is your Lenovo IdeaPad 330-15IKB 81DE failing to boot properly? Are you seeing error messages like “CMOS Checksum Error” or “Invalid Configuration”? These could be signs of a failing CMOS battery. This guide will walk you through the necessary steps and tools to easily replace your CMOS battery, helping your system get back to running smoothly!
Ce dont vous avez besoin
Ensure the laptop is powered off.
Turn the device over so the bottom is facing up.
Remove the 13 6 mm screws from the bottom of the device using a Phillips #0 screwdriver.
Carefully glide a Jimmy along the seam of the casing.
Remove the back cover of the laptop.
Unplug the CMOS connector.
Gently lift the CMOS battery out of its slot.
