Aller au contenu principal
Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Back Panel: étape 1, image 1 de 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Back Panel: étape 1, image 2 de 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Back Panel: étape 1, image 3 de 3
    • Ensure the laptop is powered off.
    • Turn the device over so the bottom is facing up.
    • Remove the 13 6 mm screws from the bottom of the device using a Phillips #0 screwdriver.
    • Carefully glide a Jimmy along the seam of the casing.
    • Remove the back cover of the laptop.
  2. Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Battery: étape 2, image 1 de 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Battery: étape 2, image 2 de 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Battery: étape 2, image 3 de 3
    • Remove the three 6 mm screws from the tabs surrounding the battery using a Phillips #0 screwdriver.
    • Carefully separate the battery connector from the device using a spudger.
    • Lift the battery up and remove it from the device.
  3. Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Speaker: étape 3, image 1 de 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Speaker: étape 3, image 2 de 3 Lenovo IdeaPad 330-15IKB 81DE Speaker Replacement, Speaker: étape 3, image 3 de 3
    • Remove the connector for the speakers from the motherboard using a spudger.
    • Gently lift the speakers from the device using a spudger.
    • Carefully lift the red wire from its dock along the bottom.
    • Remove the speakers from the device.
Matthew Bridge
Membre depuis le 10/18/24
245 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-1, Konn Fall 2024 Membre de l'équipe UMass Dartmouth, Team 2-1, Konn Fall 2024
UMASSD-KONN-F24S2G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 10
Total : 84
