Aller au contenu principal
Lenovo IdeaPad 730S 13IML/IWL Battery replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Remove the back cover: étape 1, image 1 de 2 Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Remove the back cover: étape 1, image 2 de 2
    • Start by taking out your Torx T4/5 bit from your iFixit-kit to do this. It's unfortunate companies like Lenovo have to use these kinds of screws.
    • Unscrew the 9 Torx and T5 screws from the bottom.
  2. Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery: étape 2, image 1 de 3 Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery: étape 2, image 2 de 3 Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery: étape 2, image 3 de 3
    • Pry the back cover open with an opening tool.
    • After you have the back cover off, you have access to the battery and all the other components.
    • Use a Phillips 00 bit to unscrew the 2 screws holding in the battery. Then remove the connector gently.
  3. Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery - Continued: étape 3, image 1 de 2 Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery - Continued: étape 3, image 2 de 2
    • Un-route the speaker wire, as when it comes to pulling out the battery, the speakers will get caught/possibly break if this isn't done.
    • Check that no other wires are tangled on the battery.
    • After doing so, gently pry out the battery until it comes free.
    • It may be wise to re-apply the thermal paste on the cpu, as it'll help it's thermal performance. To do this, loosen the 4 screws around the cpu, and 2 around the fan with a Phillips 00 bit.
To reassemble your device, follow these instructions in reverse order. Happy computing!
2 autres ont terminé cette réparation.
Nick P
Membre depuis le 01/17/22
1 672 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 17
Total : 2,641
