Aller au contenu principal
Introduction
The back cover and midframe of the Lenovo IdeaPad A1-07 may need to be replaced they are damaged with a scratch or normal wear and tear. This guide will walk you through how to carefully take the back cover and grey frame apart.
Pièces
Aucune pièce spécifiée.
  1. Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement, Back Cover/Midframe: étape 1, image 1 de 3 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement, Back Cover/Midframe: étape 1, image 2 de 3 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement, Back Cover/Midframe: étape 1, image 3 de 3
    • With the blue plastic opening tool, use the lock screen switch by the volume button as an access point to gently lift the back cover off.
    • Wedge the opening tool until you start hearing the back cover popping off the body of the device.
    • Slide the opening tool down the length of the device.
    • Once it is about half way off, you can use your thumb to pull the rest of the back cover off.
  2. Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: étape 2, image 1 de 3 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: étape 2, image 2 de 3 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: étape 2, image 3 de 3
    • Using a Phillips #000 screwdriver, remove all 18 of the 4mm screws.
    • With the blue plastic opening tool, gently wedge the tool between the screen and the gray frame until you feel resistance.
    • Do not force the frame off because you can break off the teeth securing the frame to the screen.
    • Push in the teeth with the blue plastic opening tool, towards the center of the device, and gently pull off the frame.
    • The gray frame will still be connected to the device by a pair of wires from the motherboard to the speaker.
  3. Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: étape 3, image 1 de 2 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: étape 3, image 2 de 2
    • The speaker in the grey frame is connected to the motherboard by the white plastic connector.
    • Disconnect the speaker by separating the two sides of the speaker connector.
Madison Cranmer
Membre depuis le 10/04/2017
370 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 338
