Aller au contenu principal
Lenovo IdeaPad A1-07 Battery Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad A1-07 Battery Replacement, Back Cover/Midframe: étape 1, image 1 de 3 Lenovo IdeaPad A1-07 Battery Replacement, Back Cover/Midframe: étape 1, image 2 de 3 Lenovo IdeaPad A1-07 Battery Replacement, Back Cover/Midframe: étape 1, image 3 de 3
    • With the blue plastic opening tool, use the lock screen switch by the volume button as an access point to gently lift the back cover off.
    • Wedge the opening tool until you start hearing the back cover popping off the body of the device.
    • Slide the opening tool down the length of the device.
    • Once it is about half way off, you can use your thumb to pull the rest of the back cover off.
  2. Lenovo IdeaPad A1-07 Battery Replacement: étape 2, image 1 de 3 Lenovo IdeaPad A1-07 Battery Replacement: étape 2, image 2 de 3 Lenovo IdeaPad A1-07 Battery Replacement: étape 2, image 3 de 3
    • Using a Phillips #000 screwdriver, remove all 18 of the 4mm screws.
    • With the blue plastic opening tool, gently wedge the tool between the screen and the gray frame until you feel resistance.
    • Do not force the frame off because you can break off the teeth securing the frame to the screen.
    • Push in the teeth with the blue plastic opening tool, towards the center of the device, and gently pull off the frame.
    • The gray frame will still be connected to the device by a pair of wires from the motherboard to the speaker.
  3. Lenovo IdeaPad A1-07 Battery Replacement: étape 3, image 1 de 2 Lenovo IdeaPad A1-07 Battery Replacement: étape 3, image 2 de 2
    • The speaker in the grey frame is connected to the motherboard by the white plastic connector.
    • Disconnect the speaker by separating the two sides of the speaker connector.
  4. Lenovo IdeaPad A1-07 Battery Replacement, Battery: étape 4, image 1 de 3 Lenovo IdeaPad A1-07 Battery Replacement, Battery: étape 4, image 2 de 3 Lenovo IdeaPad A1-07 Battery Replacement, Battery: étape 4, image 3 de 3
    • Use a plastic opening tool to push the white battery connector out of its socket on the motherboard.
    • Lift the battery away from the device.
2 autres ont terminé cette réparation.
Madison Cranmer
Membre depuis le 04/10/17
370 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 822
