Aller au contenu principal
Introduction
If your computer becomes unresponsive during use, then it is probably due to your circuit board.
Pièces
Aucune pièce spécifiée.
  1. Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Pop off the back panel using a plastic opening tool once all screws are removed.
    • Pop off the back panel using a plastic opening tool once all screws are removed.
  3. Once the panel is fully removed, begin to unscrew the battery.
    • Once the panel is fully removed, begin to unscrew the battery.
  4. Use the iFixit Opening tool to disconnect the battery from the circuit board. When all screws are removed from the battery, carefully lift the battery up.
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
  5. The battery is completely removed, and can be replaced with a new battery.
    • The battery is completely removed, and can be replaced with a new battery.
  6. Remove all screws securing the fan to the laptop.
    • Remove all screws securing the fan to the laptop.
  7. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  8. Unhook the wire from the fan component using a spudger.
    • Unhook the wire from the fan component using a spudger.
  9. Now the fan is completely removed.
    • Now the fan is completely removed.
  10. After battery is removed, you will move to the touchpad.
    • After battery is removed, you will move to the touchpad.
  11. Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
    • Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
  12. Remove all the screws holding the touchpad down. Remove all the screws holding the touchpad down.
    • Remove all the screws holding the touchpad down.
  13. Once fan and battery are removed, you are finally able to fully access the circuit board.
    • Once fan and battery are removed, you are finally able to fully access the circuit board.
  14. Disconnect the touchpad cord from the circuit board using a nylon spudger. Disconnect the touchpad cord from the circuit board using a nylon spudger.
    • Disconnect the touchpad cord from the circuit board using a nylon spudger.
  15. Then you will lift up the flap that holds these wires down.
    • Then you will lift up the flap that holds these wires down.
  16. After the flap is opened then you will have to go and remove all the screws holding the circuit board to the computer. After the flap is opened then you will have to go and remove all the screws holding the circuit board to the computer. After the flap is opened then you will have to go and remove all the screws holding the circuit board to the computer.
    • After the flap is opened then you will have to go and remove all the screws holding the circuit board to the computer.
  17. After the screws are removed from the circuit board, you will have to remove these last screws to remove it completely.
    • After the screws are removed from the circuit board, you will have to remove these last screws to remove it completely.
  18. The circuit  board is completely removed.
    • The circuit board is completely removed.
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 19
Total : 127
