Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
If the mouse is unresponsive on the screen then there is a problem with your touchpad.
Pièces
Aucune pièce spécifiée.
  1. Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Pop off the back panel using a plastic opening tool once all screws are removed.
    • Pop off the back panel using a plastic opening tool once all screws are removed.
  3. Once the panel is fully removed, begin to unscrew the battery.
    • Once the panel is fully removed, begin to unscrew the battery.
  4. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Use the iFixit Opening tool to disconnect the battery from the circuit board. When all screws are removed from the battery, carefully lift the battery up.
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
  6. The battery is completely removed, and can be replaced with a new battery.
    • The battery is completely removed, and can be replaced with a new battery.
  7. After battery is removed, you will move to the touchpad.
    • After battery is removed, you will move to the touchpad.
  8. Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
    • Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
  9. Remove all the screws holding the touchpad down. Remove all the screws holding the touchpad down.
    • Remove all the screws holding the touchpad down.
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 185
