Aller au contenu principal
Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement, Lenovo IdeaPad Flex 3 CB 11M735 Disassembly: étape 1, image 1 de 2 Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement, Lenovo IdeaPad Flex 3 CB 11M735 Disassembly: étape 1, image 2 de 2
    • It's best to touch the ground before you start to be sure you won't shock any components.
    • Use a T6 Torx screwdriver to unscrew the nine M2 x 6.5mm screws.
  2. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: étape 2, image 1 de 3 Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: étape 2, image 2 de 3 Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: étape 2, image 3 de 3
    • Using a plastic spudger, carefully lift the palmrest from the bottom cover.
    • Be careful while removing the keyboard, and unplug the connections.
  3. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement, Battery: étape 3, image 1 de 1
    • Disconnecting the battery from the motherboard.
  4. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: étape 4, image 1 de 1
    • Use a PH00 screwdriver to remove the 3x(M2x4mm) screws.
  5. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: étape 5, image 1 de 1
    • Ensure the replacement battery is right, then follow the steps backward to assemble everything.
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 7
30 derniers jours : 19
Total : 342
