Introduction
The keyboard can be damaged easily as it is one of the most used components to communicate with your device. Be sure to try disconnecting and reconnecting the wire of the keyboard since it can easily be disconnected. If that doesn't work, follow this simple instruction to replace your keyboard.
Ce dont vous avez besoin
Use a T6 Torx screwdriver to unscrew the nine M2 x 6.5mm screws.
The pieces are mostly secured with glue and melted plastic, making it impossible to put them back to getter after opening them.
That there is a barcode on some parts that, when scanned, will you to available replacement parts.
The two indicated attachments allow the keyboard and touchpad to be plugged into the motherboard. The red circle indicates the place for the touchpad, and the red rectangle shows the place for the keyboard wire.
The black plastic piece that holds the wire in place needs to be closed while covering the whole wire.
Enjoy your new keyboard!
