Aller au contenu principal
Lenovo IdeaPad Flex 4-1130 Screen Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 4-1130 Screen Replacement, Battery: étape 1, image 1 de 1
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 2, image 1 de 1
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 3, image 1 de 1
    • Remove the connector attaching the battery to the motherboard.
  4. Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 4, image 1 de 1
    • Remove the four 4mm screws on the battery.
  5. Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 5, image 1 de 1
    • Lift the battery with a spudger and remove.
  6. Lenovo IdeaPad Flex 4-1130 Screen Replacement, Screen: étape 6, image 1 de 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement, Screen: étape 6, image 2 de 2
    • Remove six 7mm screws.
  7. Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 7, image 1 de 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 7, image 2 de 2
    • Remove two connector cables.
    • Separate the two unhinged parts.
  8. Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 8, image 1 de 1
    • Use the spudger to remove the plastic caps, uncovering the screws underneath.
    • Remove the two 6mm screws.
  9. Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 9, image 1 de 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 9, image 2 de 2
    • Use the black nylon spudger to remove the long plastic covering underneath the screen.
    • Remove three 6mm screws.
  10. Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 10, image 1 de 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 10, image 2 de 2
    • Use the black nylon spudger to lift and separate the screen from the plastic back cover.
  11. Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 11, image 1 de 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 11, image 2 de 2
    • Peel off tape and remove the cable.
  12. Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 12, image 1 de 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 12, image 2 de 2
    • Remove the connector chip.
  13. Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 13, image 1 de 2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: étape 13, image 2 de 2
    • Peel tape and remove cable underneath.
Adrian Miranda
Membre depuis le 02/15/18
677 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S17-G5, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,688
