Introduction
A Wi-Fi card replacement is a quick and simple task. If you are experiencing slow or intermittent internet connection a Wi-Fi card replacement might be in order.
Pièces
Aucune pièce nécessaire.
Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
  • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
  • Remove the ten 4mm screws from the back panel.
Ajouter un commentaire
Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
  • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
  • Do not insert the spudger too deep! This could potentially damage a device part.
  • Remove the connector attaching the battery to the motherboard.
  • Remove the four 4mm screws on the battery.
  • Lift the battery with a spudger and remove.
  • Remove one 5mm screw.
  • Remove the Wi-Fi card from the motherboard socket.
Adrian Miranda
Membre depuis le 15/02/2018
677 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S17-G5, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 33
