Aller au contenu principal
Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Lower Case: étape 1, image 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: étape 2, image 2 de 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Cmos battery: étape 3, image 1 de 1
    • Using the JIS #0 screwdriver unscrew the three battery screws.
  4. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: étape 4, image 1 de 1
    • Lift up the battery from the long, bottom edge.
    • Remove the battery from the laptop and place it nearby.
  5. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: étape 5, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: étape 5, image 2 de 2
    • Remove the red and black annotated cable, pulling white head out of black port as indicated.
  6. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: étape 6, image 1 de 1
    • Ply the CMOS battery off with your finger.
    • The battery is attached to the computer by adhesive, but should come off by pulling with fingers; plying tool should not be necessary.
2 autres ont terminé cette réparation.
Elijah Ellis
Membre depuis le 11/08/18
616 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 Membre de l'équipe UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G2
3 membres
5 tutoriels rédigés
Un commentaire
Does this procedure reset the BIOS?
Mark Webb - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 15
Total : 2,611
