Aller au contenu principal
Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Lower Case: étape 1, image 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: étape 2, image 2 de 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: étape 3, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: étape 3, image 2 de 2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: étape 4, image 1 de 3 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: étape 4, image 2 de 3 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: étape 4, image 3 de 3
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: étape 5, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: étape 5, image 2 de 2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
Demario Robinson
Membre depuis le 10/02/17
1 038 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G6, Thompson Fall 2017 Membre de l'équipe USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 membres
10 tutoriels rédigés
Un commentaire
will the same fan fit to lenovo ideapad flex 5 1470 ?
Rajeshwar Choudhary - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 1,612
