Aller au contenu principal
Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement, Lower Case: étape 1, image 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: étape 2, image 2 de 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement, Hard Drive: étape 3, image 2 de 2
    • Remove the three 4 mm Phillips #0 screws holding the hard drive in place.
    • Note: A security sticker is normally affixed to the upper-right screw that helps hold the drive in the machine.
  4. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: étape 4, image 1 de 1
    • Remove the hard drive by pulling it out of its port (away from the hinges).
    • It's normal to feel a lot of resistance, especially if this is the first time the hard drive is being removed. Just ensure that you have removed all three screws.
  5. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: étape 5, image 1 de 1
    • Remove the four 3 mm Phillips #0 screws located on opposite sides of the hard drive.
    • These screws hold the hard drive in the hard drive mounting bracket. All computers use a hard drive mounting bracket because the standard holes on hard drives are not in a convenient place for direct mounting. All laptop hard drives will fit in any laptop's mounting bracket but the brackets are specific to the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: étape 6, image 1 de 1
    • Remove the hard drive from the mounting bracket.
17 autres ont terminé cette réparation.
Heeral Patel
Membre depuis le 10/02/17
406 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S1-G6, Thompson Fall 2017 Membre de l'équipe USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 membres
10 tutoriels rédigés
2 commentaires
Thanks for posting! Any suggestions on the best means to transfer (mirror) the old to new drive?
Douglas Henningsen - Réponse
This guide comes up when I click on “keyboard replacement.” Is there a guide for keyboard replacement? A search does not find one.
Greg Worrel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 36
Total : 8,988
