Aller au contenu principal
Lenovo IdeaPad Flex 4-1470 Touchpad Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Lower Case: étape 1, image 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: étape 2, image 2 de 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: étape 3, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: étape 3, image 2 de 2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: étape 4, image 1 de 1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: étape 5, image 1 de 1
    • Lift the battery up and out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Touchpad: étape 6, image 1 de 1
    • Locate the touchpad.
  7. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: étape 7, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: étape 7, image 2 de 2
    • Remove the three ribbon cables surrounding the touch pad.
  8. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: étape 8, image 1 de 1
    • Lift the base of the laptop from the screen and gently push the touchpad to remove.
2 autres ont terminé cette réparation.
Elijah Ellis
Membre depuis le 11/08/18
616 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 Membre de l'équipe UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G2
3 membres
5 tutoriels rédigés
2 commentaires
do you know where to find this part? i have been looking everywhere haha.
Hanna Tafete - Réponse
Can any body repair lenovo idea pad 1470. Touch screen ...tia
jgonzales - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,219
